Closest Carverfest Airports....
Somebody had asked me a question the other day about airports. Here is some information that will assist you better. This is taken directly off the Cabin's website....
The closest airport is Asheville, NC (airport code AVL) LINK, which is about 70 miles from Bryson City. Asheville is a very small and easy airport to travel through, and is serviced by the following airlines: USAir, Delta, United, Northwest. However, because Asheville is not a major hub for any airline, it may be difficult to find a direct flight from your departure city.
If you fly USAir or Delta, you will likely connect in Charlotte, NC (CLT)LINK or Atlanta, GA (ATL)LINK, respectively. By the time you layover in one of these cities, fly to Asheville, and then drive the final 70 miles, it might be quicker to just end your air travel in either Charlotte or Atlanta and drive the rest of the way (about 3 hours from either airport). Rental car variety and bargains may be greater in these major cities as well.
A secondary city to consider is Knoxville, TN (TYS)LINK, but don't be fooled by the apparent close proximity. Knoxville is through the Smokies and the drive is slow, difficult and unpredictable depending on time of day and season.
