LED's
If you know where to find it, let us know.
LED's
Post by F1nut » Tue Jan 25, 2011 1:13 am
I'm looking for 5mm bi-color (Red/Blue) LED's with two leads (bi-polar), non-flashing.
Make America Great Again
Re: LED's
Post by DaveS » Tue Jan 25, 2011 1:31 am
Check your e-mail or PM. James sent you some links.
Re: LED's
Post by F1nut » Tue Jan 25, 2011 2:15 am
Thanks Dave, but he was half asleep. Those were not even close to what I'm looking for.
Re: LED's
Post by Toy Maker » Tue Jan 25, 2011 4:10 am
Re: LED's
Post by F1nut » Tue Jan 25, 2011 4:18 am
Yeah, you're waking up and I'm going to bed.
I saw those earlier and sent the guy an email asking if they are non-flashing. We shall see. I was hoping to find some from a legit company.
Re: LED's
Post by BillD » Tue Jan 25, 2011 12:03 pm
You might look HERE
Re: LED's
Post by F1nut » Thu Jan 27, 2011 12:51 am
A guy on the Polk forum found some for me, but they have a $20.00 minimum order. I was going to order 10, which only came to $4.00. Since they didn't have anything else I want, I got the ones off eBay. They seem to be the same ones the other place sells....we'll see.
Thanks to everyone for your help.
Re: LED's
Post by F1nut » Thu Feb 10, 2011 2:10 am
My new LED's arrived the other day and I finally found some time to put one in my pre amp. I now have red on standby and pretty blue on full power. Way cool. 8)
Next up, replace the red one in the amp with a pretty blue one.
Re: LED's
Post by BillD » Thu Feb 10, 2011 2:32 pm
It's sometimes hard to get blue ones that aren't too bright. I've been using THESE for awhile now, which aren't blinding. a 470Ω ½W current limiting resistor on a 12Vdc line gives optimum brightness.
Re: LED's
Post by mbskeam » Thu Feb 10, 2011 3:37 pm
is a current limiting resistor diffrent than a std resistor?
Re: LED's
Post by BillD » Thu Feb 10, 2011 5:01 pm
Same thing as a standard resistor. It just describes its function.
Re: LED's
Post by F1nut » Fri Feb 11, 2011 2:33 am
Bill, the red/blue LED(s) I got did not have any specs. It was clear and too bright, both red and blue, so I scuffed it with 600 grit wet/dry, which dulled it down to an acceptable level. I tried to use the same red/blue in my amp, but both colors lit up. Would that be because of too much reverse voltage? I'm still getting my learn on concerning all things LED.
Anyway, I had previously purchased one of these, http://www.mouser.com/ProductDetail/Kin ... gub9kp8%3d, which worked out perfectly. The blue of the red/blue LED (pre amp) is a little brighter than the blue only LED (amp), but the difference is slight enough that it doesn't bother me in the least.
I hated that damn red/green LED in my pre amp from the day I bought it. Now, it looks as good as it sounds.
Re: LED's
Post by BillD » Fri Feb 11, 2011 1:30 pm
I'm guessing that you amp's LED is powered by A/C, which is OK if you can tolerate the 60Hz flicker. The LED I recommended is 20mcd, whereas the one you used were 60mcd (brighter). Congrats on the upgrade.
HERE is a little tool that can help you with those nasty little calculations to figure out the correct resistance to use. It also has a link to one to use for strings of LEDs and links to other sites about LED technology.
Re: LED's
Post by F1nut » Fri Feb 11, 2011 1:49 pm
Yeah, that makes sense. No flicker detected though.
Right, mine is brighter than yours. This actually matches the mcd level in the pre amp better and as I don't look directly at them (they sit to my right) it's a non-issue.
Thanks, I had found that doing my research.
Re: LED's
Post by F1nut » Sat Feb 12, 2011 4:31 am
I finished up the install of the blue LED in the amp tonight. What a bitch that job was. I had to disassemble half the amp, then remove the existing wires and replace them with longer runs as they were just too short to work with. I also had to fabricate a new LED holder from 3 different LED holders. Well worth the effort though. Oh, look at the pretty BLUE lights! 8)
Return to “Hard To Find Parts, Pieces, Items”
