It is currently Sun May 19, 2013 12:22 am
Sunfire 400X7 & Mtz Rec/pre vs Crvft.Tube & Adcom Pre
Post Wed Feb 01, 2012 6:09 pm
OK guys, here is the Deal. Bought a cheap used Adcom GTP-450 on the Gon to give to Matt for his birthday for use with his Carverfest Monoblocks. When the Adcom came, hooked into Dynaco system downstairs with one of the Carverfest amps. Was using a Harmon Kardon pre-amp. The Adcom sounded really good in this combo. In fact, I preferred it over the Harmon Kardon pre. The Harmon Kardon is a budget pre like the Adcom. Both are probably a decade old.
Next up was to move upstairs to compare on the Big Legacy's.
HTR used for comparision consists of Amp: Sunfire 400 X 7 & Pre-Amp: Using Marantz 7.1 receiver pre-amp outs
VS
Carverfest Tube Amp & Adcom Pre-amp
Some CD Cuts auditioned: Dave Brubeck's Take Five, Marc Cohn's Ghost Train and Perfect Love, SRV's TinPanAlley, Sara K's various cuts and other Chesky recordings.
As some of you are aware, 95% of my listening is watching concerts, which most, if not all are not what I would not consider audiophile recordings. After two days of listening, I have drawn some thoughts:
First, when I substituted the Carverfest tube/Adcom pre combo I noticed a difference in sound. Instruments had a little better separation and a wider soundstage, saxes had a more natural, reedy sound so to speak and transients had a little more attack. Vocals sounded very good with either combo, but maybe a tad more real with this Carverfest tube/Adcom combo. Brushes were more distinct moving from side to side on drum surface on the Adcom/Carverfest tube combo. All of this listening was done at around 85 db. as to not tax the Carverfest tube amp. Legacy Whisper XD's are very efficient, believe 95 db's or so., but didn't want little Carverfest tube amp to run out of headroom. No difference in Bass-will explain why later.
Next was to determine if the Adcom or Marantz HTR was the difference or the Sunfire vs Carverfest tube amp. Took Mtz HTR out of loop and inserted the Adcom with the 400 X 7 Sunfire. There was most of the difference I was hearing. Not night and day, but surely significant. The Adcom pre had a better presentation, more lifelife detail than the MTZ. HTR receiver/pre-amp combo as mentioned in above paragraph.
Comparing the Adcom as a pre with the Sunfire 400X7 vs the Carverfest Tube amp. This was a much tougher comparison. I would say the instruments may have had a little better soundstage and separation with the tube amp. Vocals were a toss up, sounded very good in both scenarios. Bass sounded the same, probably because of built in amps in Legacy's driving the subwoofers. I think I may have preferred the reedy sound of the sax with the tube amp over the Sunfire. Very close in this dept., but believe edge to Carverfest tube. Both amps sound very good and I think it is up to listener preference as to which one would be preferable over the other. Happy with either one. I would love to do this one blind tested.
My Conclusion: There is a significant difference between a dedicated 2 channel pre-amp vs using the Pre-amp of a 7.1 HTR at least in the shy side of $1K to $1.5K range while listening to audiophile recordings.
As a result of this comparison, I have on the way a VTL 2.5 dedicated 2 channel tube pre with a HT bypass. Didn't know they made such an animal until a forum member recommended. Thanks Dan for spending my money. :lol: :lol:
This should be an interesting upgrade based on my experience with the lowly Adcom.
http://www.vtl.com/pages/preamplifiers.html#TL-2.5
I have not considered yet converting to full blown tubes. Still a plug and play guy. However, my research shows tube Pre-amps are pretty darn reliable.
Stay tuned for part 2
Post Wed Feb 01, 2012 6:21 pm
Re: Sunfire 400X7 & Mtz Rec/pre vs Crvft.Tube & Adcom Pre
...I see where the $$$$ goes...remember, I still have Matt's phone #!!!!!!! :lol: :lol: :lol:
Post Wed Feb 01, 2012 6:28 pm
Great review! =D> =D> I found the same thing switching from an HK receiver to the Sunfire Pre's, almost unbelievable night and day difference. :D
Post Wed Feb 01, 2012 6:30 pm
Look who is calling the Kettle black! :lol: :lol: :lol:
Post Wed Feb 01, 2012 6:36 pm
I really, REALLY like live music played on a tubed set up. I don't know why but it just seems to shine
Post Wed Feb 01, 2012 6:40 pm
I've only had a few cheapy integrateds but found the same thing, live or acoustic music sound pretty frickin' amazing! :D
Post Sun Jul 01, 2012 11:17 am
Don wrote:Stay tuned for part 2
SO......Don; were you able to conduct part 2 or does your back have you out of commission?
Post Sun Jul 01, 2012 12:05 pm
Gary,
Have not moved seriously into Part 2 of the equation. First rotator cuff surgery, then dealing with Terri's Mom declining health and resultant passing, now down on my back since Father's Day. :( Italy vacation canceled as a result. It has been one continual issue after the other. Audio has taken a back seat. Heck, not even in the automobile currently.
Inserted the VTL 2.5 pre into the mix a while back and did get to spend a little time before all of these issues completely consumed our lives. Serious upgrade over the Mtrz. Receiver pre-outs and the Adcom 450 pre to say the least. The Adcom pre was an upgrade over the Mtzr. receiver pre-outs and the VTL 2.5 kicks it up another notch for sure. The sound stage depth and width expanded considerably with the VTL. I have a C-9 that I use occasionally while listening to a few jazz cuts. On more than 1 occasion, I got up to check to see if I had it in the loop or not using the VTL. The sound stage was that wide on a couple of particular cuts.
I do not have my 4 Carverfest tube amps currently. (you know story on that) Although not physically able to swap out, even if I did have on hand. However, when back gets better, will continue to evaluate and update listening results. Lots of different combos to try from a snergy standpoint also.
Bottom line-Make no mistake, there is a very significant difference in Pre-amps!
Post Mon Jul 02, 2012 4:24 am
Hope you feel better Don. Prayers sent for you and Terri.
Post Mon Jul 02, 2012 7:22 pm
Hey Don! Get yer a$$ out of bed already, a 1 1/2 month nap is just too much rest!!! :D
Hope you feel better soon buddy- thoughts and prayers your way!
Wait till you see what I have lined up NEXT for you to buy! WooHoo!!! :lol: :lol: :lol:
http://www.vtl.com/pages/Amplifiers/Siegfried/
Post Mon Jul 02, 2012 8:02 pm
Chauss wrote:Hey Don! Get yer a$$ out of bed already, a 1 1/2 month nap is just too much rest!!! :D
Dan,
I have a better idea. [-X You purchase and we will road show at my pad to see if the snergy is there while we put them through their paces. \:D/ The size of those monoblocks would be a little difficult to hide from Terri! :rolleyes:
Post Mon Jul 02, 2012 8:09 pm
Dan,
Wish I could! Becky said I am done with audio purchases for a good while. :( .....BUT -here is an idea for ya- O:)
They would hide nicely behind a 2-3' tall potted silk plant!!! :lol: :lol: :lol:
Return to Misc. Discussions
