Question of the day....
Re: Question of the day....
Post by angelod307 » Mon May 13, 2013 11:46 pm
jjptkd wrote:I've read all that before, it actually convinced me not to "truly" bi-amp my speakers as eliminating the passive crossovers or "balancing networks" would of been very problematic with my particular speakers.
That is the real question, if passive, 600/2 in active without hesitation 400/7 if three way and 400/5 for two way systems.
Post by Chauss » Fri May 17, 2013 9:32 pm
There are 2 different types of bi-amping- vertical and horitontal....unless you have a LOT of time and can design active crossovers....vertical bi-amping is VERY difficult to get just right and has to be designed for the amp / speaker combinations. Or- you could be in luck If your speakers truly are set up for bi-amping (have to use a jumper or strap from low to mid/high pos and neg)
Horizontal bi-amping is basically dual mono. Not sure if the 600 x 2 can be run as a massively powered mono-block,,,,but IF it can- holy crap! Your speakers better be able to handle in excess of 1000 peak watts! \:D/ \:D/ \:D/
-----I have a pair that can and are truly bi-ampable. I seem to remember recommending to someone a similar pair for sale in their area to go and give a good listen to a while back...or- maybe not, memory seems to fade. :-" :-" :-" #-o :D
Post by TNRabbit » Sat May 18, 2013 6:06 pm
The monox2 can be run as a monobloc in what Sunfire calls "parallel mono"....1200 watts into 8 ohms, capable of driving low ohm loads in this mode!
Post by Chauss » Sat May 18, 2013 7:50 pm
Thanks Rabbit!
-Hey Wayne, there is your answer!
Go easy on the volume control till you learn what your speakers can handle, :D Dual mono produces some of the best stereo imaging I have heard. \:D/
Post by OconeeOrange » Sun May 19, 2013 5:43 pm
Like most, have more than one set up.
The one I listen to most is outside on the porch.
My main $$ are in the RedNeck Bar system with my turntable which can't come to the porch. ](*,)
I have a big sub down there which can break up the muddy breaks. It is the best I have heard, but mostly wasted in that system as Bob's SunFire amps can make the mains sing.
The reason goes to KingMan's question for us to ponder. I like KM. :rolleyes:
My mains can cover the bass well with out the sub.
I use 2 Sunfire 600X2. I am not sure of how this configuration would be named, but it produces a good sound. The speakers are 4 ohm.
One Sunfire is split doing duty to the mids and highs of each speaker.
The other is split doing base on each.
As I understand it, that is 2400 watts to the bass and 2400 watts to the rest. I think that is fair as good bass requires some air to move.
The SunFires handle this with ease.
The music is quite good.
