DIY tube amps
tkd.teacher
Re: DIY tube amps
Post by tkd.teacher » Sun Feb 23, 2014 5:28 pm
hewlew1 wrote:John, You should make a Carverfest amp all of the schematics are available on this site, and essential iron is available from Edcor. Other than that the rest of the parts are readily available.A lot of us here have these already and would be able to answer your questions as well as provide direction on assembling it. 20 watts per channel in stereo or a 40 watt monoblock. A very vice little amp!
Where are the schematics?
John
Re: DIY tube amps
Post by angelod307 » Sun Feb 23, 2014 5:30 pm
Schematics are Everywere on this site to a degree.
http://carveraudio.com/phpBB3/viewforum.php?f=136
tkd.teacher
Re: DIY tube amps
Post by tkd.teacher » Sun Feb 23, 2014 5:35 pm
angelod307 wrote:Schematics are Everywere on this site to a degree.
I found the link with the images for the 20w fest amp, but the images didn't survive the transition evidently.
John
Re: DIY tube amps
Post by hewlew1 » Sun Feb 23, 2014 6:18 pm
I see what you mean john I can not find any info no matter what I click on.
bob p
Re: DIY tube amps
Post by bob p » Sun Feb 23, 2014 6:55 pm
I looked for them too and I had the same result -- nothing.
This happens a lot when forum databases get moved from one site to another. It's not at all uncommon for someone to miss moving an image directory from one site to the next while maintaining it in the same relative path on one machine vs. the other.
I think that the attachments folder failed to get copied over in the transition, and now all of the file pointers in the message database are pointing to non-existent images in a non-existent folder. if we're lucky, maybe James can restore that directory to the proper relative path location?
tkd.teacher
Re: DIY tube amps
Post by tkd.teacher » Sun Feb 23, 2014 7:40 pm
bob p wrote:I looked for them too and I had the same result -- nothing.
That's kind of what I figured, either a config problem or just missed a folder. I found a few other images that weren't available either.
John
Re: DIY tube amps
Post by mbskeam » Sun Feb 23, 2014 8:56 pm
Re: DIY tube amps
Post by mbskeam » Wed Feb 26, 2014 7:07 pm
tkd.teacher
Re: DIY tube amps
Post by tkd.teacher » Wed Feb 26, 2014 7:27 pm
Awesome, thank you very much!
I am assuming that someone who knows how to read schematics can glean a parts list out of those diagrams?
And where do you source the case for it? Any generic 6 tube case?
John
Re: DIY tube amps
Post by hewlew1 » Wed Feb 26, 2014 7:38 pm
John, you don't need a case if you don't want one. All you need is a piece of plate aluminum or steel if you wish and a step drill to make the holes for the tube sockets. The rest could be made with wood which you would set the plate material into. which would provide the depth to mount the components underneath.
bob p
Re: DIY tube amps
Post by bob p » Wed Feb 26, 2014 7:53 pm
So when you guys build this amp, how are you tuning the bias?
Are you:
a) measuring cathode current and swapping cathode resistors to tune the idle bias current, or
b) ordering spec'd tubes that have been binned according to their bias requirements, or
c) not worrying about it
Re: DIY tube amps
Post by mbskeam » Wed Feb 26, 2014 8:13 pm
C
bob p
Re: DIY tube amps
Post by bob p » Wed Feb 26, 2014 8:15 pm
OK, next question: why are you using zeners to bypass caps instead of resistors?
Re: DIY tube amps
Post by angelod307 » Wed Feb 26, 2014 8:17 pm
I will also be selling some of these amps for hopefully more than not in the near future.
Re: DIY tube amps
Post by angelod307 » Wed Feb 26, 2014 8:20 pm
bob p wrote:OK, next question: why are you using zeners to bypass caps instead of resistors?
With ten amps, i notice that the idle voltage varies, while a few are around 420, others are up to 455. My friend tubular joe came to us with a solution to help keep tubes from running away. What would be another way of making this safer for the tubes bob?
