AMPLE PLIERS EXPERT
AMPLE PLIERS EXPERT
Post by hewlew1 » Sun Mar 23, 2014 10:20 pm
Mark Weiss Possibly. But I think the sheer force of millions of cycles of alternating pulling puts a lot more stress on the surfaces than I had imagined. The floor joists are over 100 years old, reclaimed from barn lumber, and are Black Locust, which is very hard. I managed to drill a new hole and screw in the eye hook with a pliers, but it was not easy.
I was shocked to see this on facebook it was posted by Mr. Weiss. Now it appears he is trying to cut in on my action. He just has to compete with every body.
Re: AMPLE PLIERS EXPERT
Post by Snoop65 » Sun Mar 23, 2014 10:34 pm
Harry, will you be selling stocks?
Post by Chauss » Mon Mar 24, 2014 8:40 am
Harry,
I need a ratcheting left handed pump- plier to get a stubborn, eye screwed -out of my 140 yr old southern yellow pine war chest?
-Where can I find one of those? Do you have one I can borrow?......oh- wait a minute- I just figured it out.....I can just put a phillips screw you driver through the hole and just turn it! - #-o never mind...... :D
Post by hewlew1 » Mon Mar 24, 2014 9:51 am
Dan, just so you guys know that I know my shit if your suggestion does not work because you broke the screw driver, Try using an adjustable wrench (I know it is not pliers) but it will work . Just adjust it to the thickness of the metal and put it over the eye you should be good to go. And yes that southern yellow pine can be a bitch.
Take Care Dan
AMPLE PLIERS EXPERT
