Wed Dec 26, 2007 2:58 pm by Dr. W
Part 2,
This is where the gem is, so pay attention.
I got to thinking about the Phase 1000 sitting in the garage and a cleaning technique I had recently been taught by an audiophile friend of 35 years.
I believe it was the combination of the cleaning every single contact point in the 1000 and putting it before the preamp, it is currently the input point for my DAC and phono preamp.
I have taken it out several times, just to be sure. An extra set of interconnects and an active piece of equipment (according to us {used to be} minimalist audiophiles) should screw up the sound, but IT DOES NOT! I would not want to give up what this does for the sound.
You do not need any electrical knowledge. I will list what you need and how to use the items.
Oh…
why would you want to do any of the following? Depending on the resolution of your system the difference can be small to absolutely AMAZING!!!
Sweeter, smoother, more detailed, more real, better image, more depth and width to the sound stage. It can easily sound like you just invested at least several hundred to several thousands of dollars in your system with absolutely no change in your equipment, interconnects, or power cords.
The most expensive parts of this “upgradeâ€
Bruce A Weiland, my system here -->> http://forum.audiogon.com/cgi-bin/fr.pl?vevol&1317958032&openmine&zzBruce_weiland&4&5#Bruce_weiland
