got silvers today but!!!!!
mmmadog
Post by mmmadog » Thu Mar 18, 2010 10:37 pm
Had to put them in a van with padded blankets underneath. Put them speakers facing down flat. Traveled about 45 miles fairly bumpy because of some bad roads but nothing bad. Went to unload them and when I picked them up I heard something that sounded like something broke apart and was in pieces inside the back chamber for the woofers. Hooked them up and they dont sound right kinda weak and when you turn them up they make some popping sounds. Took the back chamber off and part of the crossover had fallin apart. At the top of the crossover theres a deal about 4 in. long and round with connections at each end. The outside porceline had all fallin off. This freakin sucks. Is there anybody in the Seattle area that can fix these or any advise is much appreciated..........Matthew
Re: got silvers today but!!!!!
Post by F1nut » Thu Mar 18, 2010 10:52 pm
Post a picture of the damaged part, so that we can better help you.
Make America Great Again
Post by thuffman03 » Thu Mar 18, 2010 10:57 pm
Congrats on the new speakers!
Post by mbskeam » Thu Mar 18, 2010 10:58 pm
you get those off of craigslist?
Post by Toy Maker » Thu Mar 18, 2010 11:02 pm
mmmadog wrote:Is there anybody in the Seattle area that can fix these or any advise is much appreciated..........Matthew
You could always drive them over to Bobs and have him help you :lol:
He IS right around the corner from you ya' know \:D/
mmmadog
Post by mmmadog » Thu Mar 18, 2010 11:12 pm
Yes off of craigs. It was a hassle just getting them here. I will post a pic in a bit. Getting some thing to eat
mmmadog
Post by mmmadog » Fri Mar 19, 2010 12:13 am
heres a pic maybe
Post by F1nut » Fri Mar 19, 2010 1:04 am
That's a resistor. There should have been an ohm value and watt rating printed on the outer casing, do you still have it?
BTW, that did not happen from transporting them, it was fucked already.
mmmadog
Post by mmmadog » Fri Mar 19, 2010 1:54 am
I dont know when we picked them up there was no rattling sound from the pieces bouncing around. I noticed it as soon as I stood 1 up on its side when I got home. The casing that came off is all in tiny pieces. I blew all the tiny pieces out and its not making any popping sounds anymore. For now I have them hooked to a phase linear 400. Really not getting much volume. Are they that power hungry? I have a carver 2.0t that I will hook up tomorrow see how that does. I plan on a sunfire amp to go with the sunfire pre I should be getting tomorrow.
Post by F1nut » Fri Mar 19, 2010 2:28 am
Take the back off your other speaker, see what the specs are for that resistor and get a new one.
There is no 2.0t Carver amp.
What's loud to you? Have you measured the volume with an SPL meter?
mmmadog
Post by mmmadog » Fri Mar 19, 2010 3:13 am
carver most certainly does make a 2.0t its the pm 2.0t. Iam looking at the manual right now does 600x2 @4ohm. The other speaker has the same crap bouncing around inside but I will check it and see whats going on.
Post by TNRabbit » Fri Mar 19, 2010 3:44 am
Yes, they are incredibly power hungry! Try the PM amp & see what you get...
and WELCOME~
Post by mbskeam » Fri Mar 19, 2010 8:18 am
where ya at, I have 2 tfm45 that would do the job of testing them out :D :D :D :D
mike beam
Post by BillD » Fri Mar 19, 2010 9:55 am
The PM-2.0t is just an M-1.5t
Post by treitz3 » Fri Mar 19, 2010 11:16 am
The M1.5t/M2.0 should be able to amplify the Silvers to a reasonable level. Yes, that resistor was fucked before you ever put it in your vehicle. Are you sure that you have the Silver edition ALS'?
There should be a 48" ribbon and three woofers per speaker if they are the Silvers. Also, for the crossover repair, you don't need to transport the entire speaker. Just the crossover. You will need a soldering iron, however. Were you able to get the resistor rating off the other speaker for that resistor?
[EDIT:] Can anybody here confirm that those are the original woofers? I'm having doubts here for some reason...
Return to “Carver Speakers”
