Bob Carver's "CarverFest" 20w Tube Amplifier
HOW MANY AMPS WILL YOU NEED
Poll ended at Thu Jun 23, 2011 10:20 am
1
6
25%
2
12
50%
3
2
8%
4
4
17%
5 OR MORE - CONTACT ME VIA PM.
0
No votes
Total votes: 24
Re: Bob Carver's "CarverFest" 20w Tube Amplifier
Post by Toy Maker » Sat Sep 03, 2011 8:30 am
I've told Bob to send enough parts for 75 amps... The last count I remember was around 60 or so, but I got a bunch of PMs from people asking for 1 or 2 more later. So there should be enough parts including tube for 75 amps.
if we need more, they can be shipped after CF.
I had nothing to do with the switches... If you want one, order or buy one and bring it.
I am bringing a step drill and reamer, so we can open the holes up to what ever you need.
I think the hole is about 1/4" now, but there is room for anything up to 1"
Post by Don » Sat Sep 03, 2011 8:34 am
Recommendations for switch for us newbies? It would be nice if all were the same cutout for ease of install. I know somewhere you mentioned what you and your Dad were buying.
Post by Toy Maker » Sat Sep 03, 2011 8:40 am
Any toggle switch 2 amps or mor will be fine.
I bought myself a different IEC connector that has the fuse and switch built in.
But I had to change my chassis to fit the bigger connector.
Post by Toy Maker » Sat Sep 03, 2011 8:46 am
Post by Don » Sat Sep 03, 2011 9:16 am
Thanks James.
Post by engtaz » Sat Sep 03, 2011 10:46 am
Don wrote:Toy writes:
There will be a small "Tools List" each attendee will have to bring to the class...
BYO:
Soldering iron (Bob will tell you what kind to buy/bring. no HomeDepot 500w POS.
Needle nose pliers (rounded/conical ones are best so you don't compress or cut leads)
Small screwdrivers
Small sponge and ceramic/glass bowl.
Extension cords.
Power strips (we'll need 5-10 of them)
Other items to follow....
alcohol and nylon acid brush for cleaning.
liquid flux for making solder flow better and/or for removing parts soldered in wrong place. :lol:
De-soldering Braid or solder sucker (I prefer the braid).
sense of humor because we will make mistakes.
Post by mbskeam » Sat Sep 03, 2011 11:10 am
I also have sent a countersinks, step drill, taper drill, 6,8,10-32 taps and handle not sure if these will be needed, but just in case. and a couple of small round and flat files
step drills work great to open up an existing hole, since your chassis will be aluminum, they will cut and drill like butter.
can some one bring 2" wide masking tape, this will protect the finish from the sharps that come from a drilling process.....
Post by treitz3 » Sun Sep 04, 2011 10:03 am
I'll bring a case of masking tape, no worries there.
One VERY important thing we need to cover right here and now. Whatever cabin the tube amp build will take place in will require a thorough cleanup by all that are attending. This will not be a volunteer thing, an optional thing or something that one can decide not to be involved with. It's real simple...you build a tube amp? You help with the cleanup of the shards of metal, tape, wires, solder droppings and myriad of other trash left behind by the tube build.
We are still unsure of which cabin this will take place in but we have a pretty good idea of the cabin and layout preferred. It is part of the cabin rules that all confetti, glitter and other trash must be cleaned before departure or the tenant will be charged extra. If the cleaning process they choose [the cabins] happens to involve two people or more to move heavy items, they basically have the right to make that cabin's tenants bend over and pay whatever cleaning charge they want.
For the record...we have not to my knowledge ever been charged for a cleanup fee at any Carverfest to date. That said, it's completely unfair to let the tenants of the cabin clean up [or become financially responsible] after 50 people's mess leftover from said tube amp build. For this reason only, your cooperation will not only be required but also extremely appreciated.
Post by engtaz » Sun Sep 04, 2011 11:01 am
So what is the number of people building amps because I know a few ordered more than 1? I count 20.
ekog
Post by ekog » Sun Sep 04, 2011 6:04 pm
Toy Maker wrote:I've told Bob to send enough parts for 75 amps... The last count I remember was around 60 or so, but I got a bunch of PMs from people asking for 1 or 2 more later. So there should be enough parts including tube for 75 amps.
Wow sounds like there will be a lot of amp building at CF…. Kind of like going to one of those dude ranches for vacation but instead of cows its amps.
Main System Setup:
Second System Setup:
Post by OconeeOrange » Sun Sep 04, 2011 6:28 pm
Yea, my best bet might be to go bird watching, then pay Gary to put mine together. [-(
Post by Chauss » Mon Sep 05, 2011 9:48 am
BYO:
Needle nose pliers
Small screwdrivers
Extension cords.
Tom or James,
Just wondering, are there any other items to follow besides solder, or is this it as we are nearing the Fest?
:-k
Do not forget some sort of portable / folding tables people! Building an amp on the floor will NOT be much fun!!!
Post by treitz3 » Mon Sep 05, 2011 7:34 pm
Hey Don, sorry, I must have missed this post. Extra hands and a thing of tip tinner would definitely come in handy. We have about 4 tables so far, we could use about two more, FYI. Even if it's just a card table or something.
Post by TNRabbit » Mon Sep 05, 2011 8:04 pm
I bought 3 or 4 pair of the helping hands thingies with magnifying glass for about $4 each; I'm bringing them all so I have spares. They're a little tippy, but you can work with that if you balance it right.
Post by Chauss » Mon Sep 05, 2011 8:26 pm
treitz3 wrote:Hey Don, sorry, I must have missed this post. Extra hands and a thing of tip tinner would definitely come in handy. We have about 4 tables so far, we could use about two more, FYI. Even if it's just a card table or something.
I am bringing a folding table large enough for 2...(my son's beer pong table) :lol:
Return to “CarverFest 20w Tube Amp”
