Need help from those that received drivers from Dynavox
Re: Thoughts on this subject....
Post by Scarabeo » Sat Jul 30, 2011 2:06 am
treitz3 wrote: Speakers are mechanical and mechanical things wear. For the price they are selling them for [2X what the price was 3 years ago], you deserve OEM.
Totally Agree! You do deserve OEM and that is what you Ordered and paid for and its what they claim to be offering...
Re: Need help from those that received drivers from Dynavox
Post by Mr. M-500t » Sat Jul 30, 2011 9:40 am
I agree with Tom. Don't fall the BS. You deserve what you payed for, nothing less.
Post by Eddie » Sun Jul 31, 2011 9:44 am
Here are a few pics of the drivers I got from them of the last good lot!
Post by mbskeam » Sun Jul 31, 2011 10:57 am
I put mine in less than a year ago and they fit fine.
if they can gut and rebuild then they have SURROUNDS, see if they will just send/sell? you the surrounds for your OEM woofers.
I think the OEM are better than the replacements I have now....
there are surrounds in the works now, soon I hope
jimw
Post by jimw » Sun Jul 31, 2011 4:05 pm
From Orevox:
I double checked the basket cut-out size for the existing batch and previous batch(the one with 45 degree separation mounting holes). They are within 1mm difference and both fit in 10-5/8" cut-out snugly. 10-5/8"=270mm These 2 baskets are measured 266 mm & 267 mm for the cut-out. So far, you are the only one customer had issue with it. The batches with 45 degree separation mounting holes and 266mm cut-out ID basket were built before last year and the same basket is no longer obtainable. All new batches received since last winter have been 6 mounting hole pattern with slightly larger ID of 267mm. L type terminal is the original design and we admitted it is our fault. However, the terminal is solder-able. We also can provide female connectors for customer to cut off existing speaker wires and combine them into single spade connection.
Sooo, they have changed the basket which affected the size, mounting hole pattern, and spade configuration.
They'll rebuild mine w/new cones/spiders. Looks like that's the route I'll go as there is way more than 1mm of wood that needs to come out. Not to mention drilling new mounting holes.
Now for the task of fabricating packaging for mine that will be UPS proof.
jimw
Post by jimw » Fri Aug 26, 2011 11:36 am
Got my original drivers back, freshly rebuilt. Now to find the time to install them. Soldering is one art I could never master. ](*,)
Post by TNRabbit » Fri Aug 26, 2011 12:26 pm
Soldering is ALL ABOUT the cleanliness of your TIP.
Not unlike some other areas....
Post by mbskeam » Fri Aug 26, 2011 2:44 pm
so what did they use for SURROUNDS!!!!!!!!!!!
or is the cone a diffrent OD now?
pics and measurements would be real nice....
Return to “Carver Speakers”
