TFM-75 serial#00001
Re: TFM-75 serial#00001
Post by TNRabbit » Thu Feb 02, 2012 10:46 am
We need pics, man! We are pic WHORES~
Post by MRHP » Thu Feb 02, 2012 8:21 pm
Im a pic ho myself, love seeing everybodys stuff on here. Hoping the sub cabinets turn out like I think they will. Doing Oak with a medium dark stain. Got a guy working on them but he wont let me see till they are finished. I gave him a blue print of what I wanted and told him to run with it from there. Oh yea, here is my latest arrival.
Post by jjptkd » Thu Feb 02, 2012 9:02 pm
Lookin' good!! =D> =D> =D> =D>
Oppo Sonica DAC
Sunfire TG-III
Klipsch Chorus II
Post by kingman » Thu Feb 02, 2012 9:07 pm
Lookin goooooood!!!!! =D> =D> =D>
Post by MRHP » Fri Feb 03, 2012 11:43 am
Waiting for the varnish to dry. Should be able to mount the speakers tomorrow, fingers crossed.
Post by TNRabbit » Fri Feb 03, 2012 11:52 am
Beautiful woodwork!
I'd wait at least 48 hrs for the varnish to cure throughout. Otherwise you risk the woofer edge sticking to the varnish that's not cured underneath.
Mount the woofer on the outside, right? Are you using any stuffing/insulation? For ported enclosures like that, the sound absorbing thin foam works well glued to the walls...
Post by jjptkd » Fri Feb 03, 2012 12:07 pm
Very nice! =D> =D> Your buddy does excellent work! With that PT2400 rockin' those things it's going to sound incredible, congrats!! =D> =D> \:D/ \:D/
Oppo Sonica DAC
Sunfire TG-III
Klipsch Chorus II
Post by MRHP » Fri Feb 03, 2012 1:28 pm
Yes the woofers mount to the outside. Ill get a pic of that operation when we put them in. Those W7's mount really strange. I got 5lbs of stuffing and some 1/2 inch thick acusta foam thats just peel and stick. Gonna experiment with what works best. All my Dalquist speakers are stuffed full and the ported ones have incredibly deep base for their size. So it seems more is better. I may stuff one and not the other, then do a left right comparison.
Post by jjptkd » Fri Feb 03, 2012 1:37 pm
From what I understand, the stuffing is supposed to be loose laid as in not packed tight, just enough to fill the space. Also, it slows the internal air movement, tricking the woofer into acting like its in a larger space then it has and will change the tuning a bit, might want to refer to factory recommendations as that's a factory spec box. Lining the cabinet on the other hand is a whole other issue but if the material is a half inch thick, I'd be concerned again that it will subtract from the internal air space and change the tune a bit, maybe both together works out? I don't know. :-k
Oppo Sonica DAC
Sunfire TG-III
Klipsch Chorus II
Post by MRHP » Fri Feb 03, 2012 2:38 pm
We did make the box about 1" bigger everywhere to make room for the cabinet lining. Ill probably line both and the try the stuffing loose and tight. Gonna be fun no matter what!
Post by Scarabeo » Fri Feb 03, 2012 6:42 pm
Looking Good Man! You going to use that Rifle to get more kick out of the sub? :lol: :lol: :lol: Nice woodwork...
Post by MRHP » Sat Feb 04, 2012 11:06 pm
Wow! Thats what Im talking about! I only got one hooked up and its shaking the house...lol
Im not gonna need the rifle, this thing has plenty of kick :D :D
I will put up some picks tomorrow. One thing I noticed big time is how clear and undistorted the highs are now that I took 150hz and below away from the DQM-9's. Kind of a home made bi-wire setup.
Post by TNRabbit » Sat Feb 04, 2012 11:14 pm
.....more akin to biAMP than biWIRE....
Personally, I'd consider lowering that crossover frequency....subs should be invisible.....& they aren't above 50 hz....
Post by MRHP » Mon Feb 06, 2012 8:43 pm
Yea I figured the 150hz might be a little high but had to start somewhere. Im using the Harrison FMod inline crossovers. 150hz and down to the PT-2400 and 150hz and up the TFM-75. Its working pretty good for now. Soon as I learn how to work the Sunfire TGP II it has a built in crossover that is adjustable down to 80hz which should help alot.
1/2 inch foam in the cabinet
Wiring the speaker before installing in the cabinet
Post by kingman » Mon Feb 06, 2012 8:50 pm
Crankin time!!!!!!! \:D/ \:D/ \:D/
