TFM-75 serial#00001
Re: TFM-75 serial#00001
Post by angelod307 » Mon Feb 06, 2012 9:41 pm
i use, as well as many others use, a pound of fill to the cubic foot of air space. a little more and it dampens a bit more, like 20-24oz to the foot and in the end you trade efficiency for lower tone as the fill will mimmick a larger box than is there. i would also, although a little harder now, put a brace or two on the side walls to back wall, as well as side to side. the more solid the sides, the more output you get that the box itself doesn't absorb up and again the lower it will play without the flexing sucking up the lowest notes. the braces are only relavent if you play it loud, really loud even though you might notice it at lower volumes as well. a rta will show it easy like. and because i did not say it in the first part of the post, very nice work by the way. daddy likes...
Post by MRHP » Mon Feb 06, 2012 10:29 pm
I have one filled and one not. At first I havent noticed much diference. I even used the AudioControl warble tone mic and tested the db readings from right to left @ 31.5hz. without much difference between them. Gonna have to play with it a little more to see what is working best.
To mount these speakers first take off the outer aluminum ring.
Then remove the inner stainless ring.
Then fold uip the rubber surround and expose the holes for drilling in the wood screws.
Post by MRHP » Mon Feb 06, 2012 10:48 pm
Heres a few pics of the final product. Turned out great and the bass reproduction is unreal! The windows upstairs vibrate and distort slightly when you look at them in the sun light...lol
Post by engtaz » Tue Feb 07, 2012 3:44 am
=D> =D> =D> =D> =D> =D> Very nice work. Congrats
Post by kingman » Tue Feb 07, 2012 7:30 am
Good job!!! Enjoy the music!! =D> \:D/ 8)
Post by jjptkd » Tue Feb 07, 2012 10:29 am
Just wait until you get the TGP-II in the mix, everything from the bass response all the way up should improve quite noticeably!! :D :D
Oppo Sonica DAC
Sunfire TG-III
Klipsch Chorus II
Post by MRHP » Sat Feb 11, 2012 10:31 pm
Got the isolation spikes installed. And built some billet aluminum pads to set them on.
Post by engtaz » Sun Feb 12, 2012 1:52 am
You've got skills. Schweet
Post by elgrau » Sun Feb 12, 2012 1:02 pm
Looks like a system that really COULD blow back your hair re that old seventies ad for Pioneer stereo (or some such system from that golden age of hi-fi). Happy extreme listening. Hope your neighbors understand that LOUD is an addiction that must be fed (and a TFM-75 can definitely dish it out!)! :lol:
Post by MRHP » Sun Feb 12, 2012 1:30 pm
I tell ya this setup has almost unlimited bass. I turned it up last night way past what I thought the speakers could handle and it just got LOUD and more clear. The 75 was just idleing not even sending the needles to half way.
Im now fully hooked on Carver crack and just bought a Sunfire 600x2 from a forum member. Looking at the RE Audio 18XXX subs to be run by the 600x2. These subs weigh 115lbs.
The wife is probly gonna kick me out of the house soon :lol: :lol:
Post by tinpan » Mon Feb 13, 2012 9:28 am
Wow, that whole set up looks nice
Post by MRHP » Mon Feb 13, 2012 11:03 pm
Thanks! I got the Sunfire TGP II hooked up now.
Post by jjptkd » Tue Feb 14, 2012 10:08 am
Lookin' good. You might want to be careful stacking so much gear, I'd hate to hear about dented / damaged top covers etc. looks like you've got 100lbs sitting on the TFM-75 right now all bearing down on the four little feet of the PT2400. Did you notice a difference with the new Sunfire preamp? :-k
Oppo Sonica DAC
Sunfire TG-III
Klipsch Chorus II
Post by MRHP » Tue Feb 14, 2012 12:09 pm
I have just been thinking about that very thing. Gonna start looking for a system rack or maybe make one.
The Sunfire pre has a much warmer tighter sound. Its hard to explain...you can just hear the quality in it. It has so many options I havent used a fourth of them yet. :lol: :lol:
Post by MRHP » Fri Apr 13, 2012 9:18 am
Got some dedicated lines under way \:D/ Should pull around 105+amps at max power just from the amplifiers. :lol:
