Thank you, James!
Carver Research Forum, Everything Lightstar, Lightstar, Lightstar,
BlueMDPicker
Thank you, James!
Post by BlueMDPicker » Sat Sep 21, 2013 12:05 pm
My beloved Lightstar Reference amp (number 003) ceased output recently. All I could imagine was this 80 pound pristine treasure having to make a jarring coast-to-coast-to-coast journey for repairs. Thankfully, I PM'ed James for some insights and he graciously took time from Carverfest to supply the info I needed to work around the issue. I am listening to it sing as I type. WOW! What an amp! I can't thank James enough for the help. You just can't beat Carver audio enthusiasts.
The workaround fix is shown in the mid right of center of the photo below. Thanks also to Dr. Bob for including that simple piece of circuitry. Whew!
Re: Thank you, James!
Post by Snoop65 » Sat Sep 21, 2013 11:13 pm
What was the cause and what was the fix?
BlueMDPicker
Post by BlueMDPicker » Sat Sep 21, 2013 11:21 pm
Cause = relay from front panel touch switch inoperable.
Fix = turn off/bypass front panel touch switch with internal slider.
Post by Snoop65 » Sat Sep 21, 2013 11:38 pm
From one Lightstar owner to another thanks!!! Hopefully I will never have to usoe the bypass.
Return to “Carver Research (Lightstar)”
