Let the fun begin Building Lightstar amps from the ground up
Carver Research Forum, Everything Lightstar, Lightstar, Lightstar,
Post by Toy Maker » Tue Nov 06, 2007 10:38 am
Phantom602 wrote:Did you get the Transformers? If not what are your plans to get transformers built?
Do you know anything about the original transformers at all ??
Phantom602
Post by Phantom602 » Tue Nov 06, 2007 11:35 am
I know they are custom built ones with very low impedance. The low impedance is the key. Without this the transformer could not diliver the current when needed. You did get the transformers right?
Post by Magnaryder » Wed Nov 07, 2007 9:18 am
Toy Maker wrote
This looks like it will make for an interesting weekend... or 10
Hey Ray... can I be in your little club now ??? pleeeeeeeease....
Got Wood ?
Got wood Hell!!!! I'm sporting a Sequoila(sp). Looks like you and Dave are the defacto leaders of the pack. bastids :-) Gee, are 2 Lightstars enough to gain admittance?
Post by TNRabbit » Wed Nov 07, 2007 11:14 am
Drop the "L", Ray. SEQOUIA.
By the way, like your new sig tag line!
Post by Toy Maker » Wed Nov 07, 2007 5:07 pm
Phantom602 wrote:I know they are custom built ones with very low impedance. The low impedance is the key. Without this the transformer could not diliver the current when needed. You did get the transformers right?
The reason I ask is... I got all the parts for 4 amps... minus 2 transformers ( I have 6 )... I have Sunfire working on the other pair. I hope Rita will be able to pull some magic out of her hat of tricks.
Roland says he is prett sure the Sunfire Signature 300x2 tansformers will work just as well. Problem is... that's a China part, and I don't know if Sunfire can scrape up a set for me.
Post by treitz3 » Wed Nov 07, 2007 9:39 pm
It'll cost more than a dime, but you can have a specialty x-nfrmr shop custom build you two if you have one you could give them. Keep in mind, they MAY have to destroy the one you give them to do so. [estimated 600-750 per x-nsfrmr]
Post by Toy Maker » Wed Nov 07, 2007 10:13 pm
treitz3 wrote:It'll cost more than a dime, but you can have a specialty x-nfrmr shop custom build you two if you have one you could give them. Keep in mind, they MAY have to destroy the one you give them to do so. [estimated 600-750 per x-nsfrmr]
Know of anyone ???
Post by treitz3 » Wed Nov 07, 2007 10:26 pm
There's a shop in Matthews, NC that the company I used to work for got there work done at. I'll drive by tomorrow and get the company info. if I can find the time. [I'm swamped] If not, ASAP.
If they are out of business or something, I'll give Greg Franklin a jingle. He's the head of R&D. He'll know where to go.
Phantom602
Post by Phantom602 » Wed Nov 07, 2007 11:37 pm
This company can build it for you.
Give them a call
http://www.toroid.com/
Post by treitz3 » Wed Nov 07, 2007 11:46 pm
Nice find 602! These guys are the real deal.
Post by Toy Maker » Thu Nov 08, 2007 8:37 am
Phantom602 wrote:This company can build it for you.
Give them a call
SWEET !!! I called them and left Ming, a message, Let's see what happens. THANKS MAN !!
I also found an original service tech for the Lightstar amps... waiting for a reply from him too.
Phantom602
Post by Phantom602 » Thu Nov 08, 2007 9:10 am
If Toroid of Maryland can not help you out let me know. I know one localy that can do it. We do about 2 million in business with them so I can pull a few strings.
Post by Toy Maker » Thu Nov 08, 2007 10:29 am
Do you think having the actual transformer will be enough to get a few made ?? I do not have anything on them as far as specs go.
I need (2)... if they rip one apart to make the new ones, I will need (3).
Might just be a good idea to go ahead and make a few extra huh.. say 8-10 ?
Phantom602
Post by Phantom602 » Thu Nov 08, 2007 11:43 am
A good transformer company can measure the electrical and resistance to get the design needed. It is unlikely the transformere will need to be damaged. If it comes to that then I would go ahead and get a few extra built.
anatech
Hello everyone!
Post by anatech » Thu Nov 08, 2007 3:04 pm
Hi everyone,
My first post here.
Those are EI core transformers. Nothing really special about them. Do not try toroid types. The inrush current will be silly and the originals use the top plate as a heat sink (along with the outputs). The down converters use the sides as a heat sink and are thermally decoupled from the top.
If anyone knows where Vic Richardson is, talk to him. He is the engineer who finished this design and put it out the door. I'd love to say hi to him again.
So, the transformer. It should be around 180 VAC center tapped. You can measure the core size to get an idea of what the wattage is. Oversizing it slightly will not hurt as long as the two still fit.
Where ever did you get those PCB's from????
If you see any with heat sink grease under the output transistors, I probably rebuilt them. IF you don't, they should be taken apart and cleaned. We did have trouble with debris under the transistors that would sometimes short. This can take a while to happen. Get it before it gets you! Also, the feedback resistor needs to have the wattage at least doubled and stood up off the PCB.
-Chris
You did what???!
Return to “Carver Research (Lightstar)”
